Tram line feel
Car  172 Cup
I replaced my rear suspension a month or so ago and got rid of the tram line feel I had. But its back again, and I'm sure the suspension would still be fine.
Is it a common problem? And any ideas what I should look for? Or a part I most definitely should order?
Have you actually checked your rear shocks? I know you've only just replaced them but you never know.....I discovered one of mine is shot, after only replacing them a year ago :(
It will make it wander around, especially if you are carrying a bit of speed round a corner!
What tyres are on there ? What condition are they in ? Checked pressures ?
What size wheels have you got on there ? Tramlining generally comes from over-size wheels, i.e.: 17's on a clio, 19+ on a BMW etc..
Check shocks as suggested.
Have you had the geometry checked ? Have you had someone follow you to see if it's crabbing or anything instead ?
I'd be looking at the front - check for play in any joints. Then get tracking done. The mention of tyres above is also a good call - if they have uneven wear or generally quite low on tread then it will exagerate any tendency to tramline.
