tripometer problem
Car  Fabia VRS Special Ed
I recently took my clocks apart, but put them back together properly.
However now, the tripometer isn't working properly, the mileage and the other displays are working but the MPG & range seem to be flashing ----
Anybody had this problem previously or know how to rectify?
Thanks in advance
Liam
Have seen people on here saying they had similar problems to this problem because they tightened up screws too much behind the dials. They loosened them off and all was well again.
Thanks for the reply, I tried this before and it didn't appear to make any difference :(
you can reset them....... from memory you hold the stalk button and switch on ignition(still holding button)
everything on the dash should move dials etc. then from memory you click the stalk button to the mpg bit and press the mileage reset button.
again from memory. it may be you press the trip reset button then the stalk but i think its the first one i said.
doesnt cause any problems and takes seconds
I officially love you :)
this worked and the tripometer is working perfectly again :approve:
It is also a sign that you're battery is on the way out.
nah it's sound matey, check it regularly at work and it's perfect :)
no problem. feeling the love.
you dont know how long it took me to find that code out when my ph1 had the same problem......
must off been about 8 hours of searching the net!!!!!
but glad it worked
