Trye Pressures
i always put 28 psi in back 30 psi infront in my mk 1 clio
that cant be far off id suggest same or maybe 30/32 f/r
adi
My Mk1 on 195/50/15.. I used to run 32psi all round.. I then changed it too 34 psi all round - I like it so much better!
Daz.
SHHHHHHHHHHHHHHHHHH!:oops:
Its strictly for "educational" purposes.....and the doctor said i needed some exercise, so I started on the right hand....that was in 94 tho, wonder if i should start on other parts of me body.....
lol..... Na you dont want to be exercising all day best way is to carry on building up your right hand coz you know its quick and simple with that.... Poor girls eh....
pressure is pressure guys, not an amount of air, unless your car is somehow heavier than usual then use the pressure you were using before, maybe 1-2psi increase if your wheels have gone up in size by 2"+
just try 32 an go from there, if its too soft for you then put it up a bit
