Trying to put Phase 1 seats in a Phase 2, Air Bag Light issue
  Clio 172
OK, I'm trying to put my phase 1 seats into my phase two as they're in much better condition. However I get the airbag waning light.
I've used a diagnostic tool and its all relating to the drivers side, the passenger side is giving no faults.
Fault Codes are:
36913 SEAT POSITION SENSOR DRIVERS SIDE -Disturbed Function
36882 DRIVER BELT PRETENSIONER - Fault in Electric Circuit
36875 SIDE AIRBAG DRIVER - Fault in Electric Circuit
When I did the swap I used the seatbelt pretensioner etc from the Phase 2, on the Phase 1 seat on the passenger side (i had no choice as the pretensioner had fired when the Phase 1 was smashed)
On the drivers side I used the Phase 1 pretentsoiner, on its Phase 1 seat.
I've matched all the wires under the seat and connected them together, 7 from the seat, a blue/brown/black under the base and a blue/brown/pink/grey from the seatbelt. These have been connected onto the multi-core cable from the car.
I've even tried the Phase 2 Pretensioner on the Phase 1 seat on the drivers side, but I still have the air bag light.
Any thoughts on what could be causing this?
Djw John
Scotland - South
When I did it I found there was a micro switch on the ph2 runners that I couldn't fit on the ph1 seats. When I closed it the light would go off but don't cut it off as then it stays on. That'll be the seat position one I reckon.
  Clio 172
The micro switch is there to see if the seat is fully forward, to adjust the airbag deployment accordingly. So it should be possible to have the airbag light out with that open or closed. As it would only be closed with the seat fully forward.
I've connected it and tried closing it, but no joy :/
