Morning! You guys might not no the answer as most of you run N/A i know but still woth a shot. Plus i know some people from the RTOC use the boards ( i will also post on there when i have sent my cheque of and can get back on the boards lol)
O.K last night i had some turbo trouble, i was not on gas and not really giving the car death, i put my foot down in 4th gear to overtake a lorry as i got infront my car juddered and felt as if it was going to die, i let of the accelerator and then pressed it again and it was fine. I was very low in fuel and was goin to a station anyway, so thought it may have been the low fuel. I filled up and off o went, as i got back on to the dual carriage way i put my foot down in 2nd gear and it boosted fine (up to 15psi @ manifold)and started to boost fine again in third, untill i hit around 4k, at this point it just hesitated and died again. It was fine again when i let of the accelerator and gently pressed it again.
It did sound as though i had a boost leak, but when i got home i had all boost hoses off from turbo to intercooler and then from intercooler to carb top (this is a 5 gtturbo engine by the way) and i could find no splits or leaks in any of them. This morning it was the same on the way to work, boosting 100% normally and fine in 1st and second, but then not in any other gear it will die shortly after i get into 3rd. Now if it was a boost leak (which i still think i can hear) i would not have thought it would affect the higer gears only like it is doing, plus the place i susspect it could be leaking from is a 4mm boost gauge pipe which seems to have been pulled of from the back of my clocks (i also would not have thought that would cause any noticeable ammount of boost loss)
Has any one any ideas, or does it sound as if my turbo has seen better days? There was no oil in any boost pipes, or the intercooler, or around the turbo.
Cheers Paul
