Turn on as car turns off?
Car  MK2 Clio
Does anyone know how to wire something to draw power when the car is off, when the car is on (or ignition is on) it will turn off?
Many Thanks
Easy with a relay. Wire the coil to the ignition live then whatever you want to turn on to the normally closed pole of the relay via the battery.
This however is a really good way of flattening the battery!
@ Rob - I like the cut of your jib with the flamethrowers idea!
@ Sparky - Very easy to do this but you need a 5 pin 12v relay rather than a 4 pin unit that is rated accordingly for the circuit you want it to switch (Though most are either 20A or 40A and are capable of switching most general electrical items). As above by Ian_S, don't try to run something with a heavy pull as you will come out to a flat battery and get "click, click, click, click" from the starter.
You should be safe with that... pretty sure you can buy these as a fully built or even a DIY build kit from Maplins
Or why don't you get a Clifford? - good alarm, insurance approved, loads of features - it even has a real flashing light ;)
I got one in mine for around £300 IIRC - the FIRST thing the car was booked in for when I got it
