TYRE PRESSURE & OIL
  Clio II 1.4 Priveleg
Read your handbook. Tyre pressures recommended by the manufacturer should always be used. Look at the index and find tyre pressures, normaly at the front of the manual (page 3?)
Oil recommendations should also be found in the manual.
Most engine oils are compatible but only use COMMA to fry your chips, but dont eat them afterwards!
BRUN is spot on regarding TPS
Renault use the BAR system. 1 bar = 14.7 PSI
EG: 2 Bar = 29.4 psi
