tyre wall gel
Car  Cupra K1 & Clio 200
hi, i normally use a spray, and dont get the dark black shiney look im after! what gels out there will do the job?
Hon
Autoglym Vinyl and Rubber is a spray and works well for me.
Gel wise, Meguiars Endurance is good.
Turtle Wax tyre gel is good! (lime green bottles)
i got 4 bottles when it was BOGOF at halfords lol
Megs Endurance High Gloss here
Chris
It does lasts well, even through rain.
When you wash the cars unless you scrub the tyres it stays on as well.
but it does take a few applications to get it into the tyre wall, at the moment mine fades after a few days or just ends up down the side of the car
I have never had a problem with splatter from the Endurance. It works best on tyres that have been really cleaned and scrubbed first though.
I've had splatter when I've done a rush job and put too much on. I put a thin beed around the tyre and move it around with a paint brush, finally evening out and mopping up any excess that can fly off with an applicator pad.
Chris
I didn't really fancy spending that long dressing tyres, but I guess if it lasts twice as long you only do it half as much.
I used turtlewax "wet'n'blck" spray, then simonez "tyre black etc" (which was poor) and currently I'm using armorall tyre stuff which is really great, but lacks staying power.
It doesnt really take that long to do them, 10 mins max couple of mins at each tyre. Worth the extra few minutes as it does a better job than the quick fix sprays that wear off if some one brings a cup of water by them.
Sprays are ok for a quick impressive result but for endurance you'll be needing a gel, applied with care.
I've used Supagard and Meguiars sprays and another down point with them is that they can leave a mark on your drive, especially in the summer when the ground is dry.
Chris
Does'nt take more than a few mins to do all the tyres here for me. A nice thick inch and half paintbrush or foam applicator.
Thanks for the replys, i will be looking out for the meg's endurance in halfords when im next there. will give my tyres a good scrub in the meanwhile! :D
Hon
The Big Yin said:
Dont you recommend to use AG machune cleaner first to get the sh*t off
Indeed - a good scrub with AG Engine and Machine cleaner or Meguiars APC to get the tyres nice and clean is must first.
