^ what pete said, it also down to the setup, your fronts ect, do you know what you front start playing at?
eg if your front play say 100hz and up play your sub from 100down, but the main thing is, select one, listen for a bit then change, then listen the change ect
what front have you got? whats the HP filter set to?
