Dr HMS Derv Destroyer
MK1DCi/vivaro/REN’11
hi all, something happened last night to my dci whilst on a spirited drive. 3rd gear going into the boost range and a little ' pisssssssh ' noise followed by loud boost noises. in other words, on idle you can only just hear the whistle but when the boost racks up the whistle gets louded until turbo is at maximum psi.
whistle noise still happens but power is only a tad lower than usuall, still pulls on boost but not as it did.
now, i had all the boost pipes off for inspection but no splits in any. also replaced every jub clip with new ones and tightened down securly.
then went on to check the waste gate to see if its venting off accessive boost but the rod isnt moving ( unless they dont on dci 80 turbos )
FYI turbo cannot be blown as the noise only happens on spool up and there is NO smoke out the back other than usuall diesel sutt.
did take it to renault in hinckley but the tards there presume my turbo has had it. but they got rather confused with the lack of white/blue smoke to idicate turbo failure.
anybody in the know how?
