Up rated ECU
Car  PH1 172
Does anybody know if I can get an up rated ECU and spend the money wisely instead of buying a standard ECU again?
erm you mean a remap ? the ecu is fine but it can be tweaked via 'remapping' the 'map' by changing fuelling, timing, and ignition.
see rstuning, bell-autos & fastchip via search !
Looking at his other thread wolf it seems he needs to replace his standard ECU and is looking to see if theres anything similar for his car which is better and worth the upgrade.
Spot on........sorry about poor info in 1st post
Omex is more expensive aye, but then it's also miles better as there's so much more you can do with it. On a stock engine you'd get better gains than any custom Renault ECU mapper can achieve.
