Upgrading Speaker Wire - Worth it?
Car  Twingo Dynamique
So I have on order an FLI Underground 4 channel amp, and have sitting here at home the FLI Underground Comp 5 Component speakers... I've got some speaker wire on order anyway as I am going to put the old front speakers into the rear as it's a POV spec clio! :/ :L
I know its a bit of a PITA putting uprated speaker wire into the front doors, but will it be worth it?
I'm also mounting the new tweeters into the existing tweeter grills, as they do not fit the brakcets renault supply. Think it will look CRAP mounting in the little cups that they come with so that they face me more? or will the sound be improved enough for it to not matter????
Cheers for your opinions folks!!!
so from my amp, i should just run the speaker wire up to where to connect to the existing wires...?
I run it to the back of the head unit. Usually I cut the extra loom that most stereos need and connect it there. Means when going back to standard you just remove the look adapter and the wiring is back to normal again.
cheers mate... although as clios have tweeters as standard, wont that be going through a crossover... somewhere...? :L :/
