upper gearbox mount, easy to change?
s**t sorry I though you were after dog bone. Still easy battery out and jack under the engine to support.
Not rocket science.
Airbox and battery out.
ECU brace out for space.
Mount is then staring you in the face.
Remove big 18mm nut from memory,
t**t stud with hammer. Gearbox will drop down. Have it half supported.
Two 10mm nuts out. Make sure you catch the bolts from below if possible.
Done.
