Upper gearbox mount guide?
Take the airbox off, remove the bolt that holds the battery in place and remove battery (im not sure if you need to put a jack under the box when you remove the mount but it might be safer doing so), remove the mount, fit the new one, fit battery, fit airbox, enjoy.
Thanks a lot, so no need to remove the 'spider' and bracket? ie these bits: I can just remove the mount via the three bolts with these bits in still on the car?
Ive just done mine and its far easier to remove the complete 3 legged bracket and the part that mounts to the chassis leg.
you can do it by just removing the mount itself. can sometimes need persuading off slightly as the top metal plate deforms slightly.
