Urgent help needed!!! :s
Car  Clio 182 Cup
Hi
Wonder if anyone could offer some urpgent support. I have a Clio 182 Cup and today when i try and lock it it beeps 3 times then does a high pitch sound as if i havent closed the doors, boot, bonnet ect. I have tried turning the key 3 time sin the ignistion then locking it within 20 seconds, that did not work, I have also tried using the other key, that does not work either. Its as if the exterior alarm sensors are detecting a door open when they are not. Does anyone know anything of this problem? or wether there is a way of removing the fuse or even putting an end top this awful sound?
Thanks in advance:S
This happend to my 182 within a few days of owner ship.
The problem was that the sensor that detects if the bonnet is open or not had pushed downwards out of its holder/clip thingy and was obviously breaking the circuit as it was not compressed.
I put the sensor back in place and a dab of glue to hold it there and this solved the problem. Also try and see if the sensors have got any grit in. Get someone to lock the car which you push each sensor in and see if it arms.
Cant think of much else to say.
Sam!
Thanks for your quick responses, Does anyone know where the sensors are for the doors? so I can chekc those aswell?
Mine sometimes does this, and i was told it was due to the alarm system being too slow and not being ready to arm when you press the fob, a quick unlock and then lock again sorts it, or just get out of your car slower! :boring:
