get in touch with henk mate he'll be best placed to help. Give him all the map info etc and what your cars firmware etc is/was.
I was under the impression that as long as you don't turn the car or pc off midway through re-mapping it's usually just a case of rewritting the cal or rst file so it shouldn't have borked the ecu. But the fact you cant connect to the tuner is a worry obviously.
ive put my other ecu in it now and it works, henk has reccomended using a battery charger and then trying to connect using the rs tuner so i may try that this evening
