Urgent Help Required
Car  clio 200
my car went down to renault last week for top mount mod and a new lower arm and since then have had a strange clunking noise from same side as new lower arm on full lock
went down again today and now they are saying i have a problem with my driveshaft on that side
would the drive shaft have been tinkered with when fitting a new lower arm as the noise has only developed since fitting it
and would a 40 mm drop cause drive shaft to pop out as thats what they are trying to blame it on
im not 100% sure m8 but they took it on a test drive and heard it pop, they think it has popped out but you know what renault are like for giving you the full story
so would the drive shaft been out/messed around with to fit a new lower arm m8
yes passenger side i think thats which side i had new lower arm fitted.
is it a common fault??
wats your advice m8 as they are going to try and charge me for it
find out whats damaged, ask to see the parts if needed, DON'T be fobbed off
i've seen LOADS of outer gaitors "pop" off
i find it hard to figure out WHY/WHAT is damaged, the drivers side one is the weaker one IMO
well just have to wait and see but like i said have had this strange noise like a clunking when on full lock on the passenger side since they fitted the new lower arm and today found out that i have some sorta problem with the driveshaft or thats wot they think.
but will have to wait to hear tomorrow thanks fred!!!!
