Urgent! Passenger window won't close!
Daz.
Car  Clio 200 RS EDC
I opened both my windows as normal this morning to get rid of the condensation but the passenger one refuses to go back up!
The drivers is fine and the relay clicks as normal when you use it.
The passenger one is dead! neither switch will operate it nor will the relay click if you use either.
Obviously my main concern is getting the window shut!
Can this be done manually?
I can't see any way of doing it manually and I've searched on here but no luck. I have read however that if the relay isn't clicking it's the switch?
Surely both switches can't have gone at the same time?
Gonna have to cardboard it up at this rate!
I assume you have checked the correct fuses? Could be that.. I'm sure someone will correct me if I'm wrong! :D Good luck!
Nah tried that - that would have been too easy!
It's covered with cardboard at the moment but i'm worried about rain obviously.
Took the door card off and had a look I can't see anything wrong (that door card has deffo never been off before!)
I 'think' I can hear the motor attempting to click or thud but it won't budge.
Supposed to piss down tomorrow too :(
The fuse covers both sides so if that had gone neither would work.
Maybe if you have time, disconnect and reconnect the battery?
My Megane went in for its service, passenger window was completely stuck, they replaced my battery as it was on its last legs, and the windows have been fine ever since.
Could be worth a shot?
Battery is off now for a while - plus it's security!
Got to go to bed now I'm shattered!
Ok update:
Got a new window regulator off cliospares - easy as pie to fit!
Window went down - sorted I thought!
Bloody won't go back up again now! :(
So to me the next thing to try is the switch as it clearly goes down and if you press the down button it tries to go down again but is it like the mk1 where if one side goes (switch) neither work?
Pissed off because I don't know which switch to buy!
