Urgent radio help
How do you enter the radio codes ive worked out how to imput them but still not working, do i have to press anytning after entering the forth number
tells u in your owners manual how to enter it and the number is in your service manual on the inside page. Whether that helps!!!
Think you have to use the little controls beside the steering wheel. When you put the last number in you hold the button in that you use to move onto the next number. Hope that makes sense, been a while since I used my standard head unit
as above. think it makes you wait if you put the code in wrongly (it just reads 'CODE'). you need to leave the unit on for 1 minute before it'll let you try again; get it wrong again and the delay's 2min, then 4min, etc
