The connections are the same. However, the radio will only go up in even numbers. As Dan said. Some units you can change this, other's you can't. If you do not listen to radio. It isn't an issue. If you do, could be a problem. Usually, there is a setting hidden in the HU somewhere to alter the way it seeks stations.
