At least it is a starting point, it is always better to start off with a base cost and work it up to include anything else that might need doing rather than over quoting.
Ha. And the rest.
Full works on mine with Fred was a lot. Painful side of £2k.
1 Renault Cambelt Kit
1 Renault Aux Belt Kit
1 Renault Clutch
1 Renault Slave Cylinder
1 Renault Thermostat
1 Renault Water Pump
1 Seal
1 Seal
1 Piper X Clio V6 Panel Filter
6 NGK Plugs
1 Renault Oil Filter
3 Litres Fuchs Titan Gear Oil
6 Litres Fuchs Titan 5W40 Fully Syn Oil
15 Litres Renault Type D Coolant
2 Renault Rear Ball Joints
2 Litres ATE SuperBlue Brake Fluid
1 Litre PAS Fluid
2 Renault Exhaust Clamps
2 Bleed Screws
15 Hours Labour
That hurt. Trouble is, as the lump's out it's easier/cheaper to replace bits than hope they make the 10 year service...
meeeow indeed! Customer asks for everything to be changed i don't see the point in leaving it all in place to struggle with
