portal172 said:
portal172 said:haha
Sorry dude, didn't mean to take the piss.
The V6 only fits in the back. Check out the Clio V6, if you aren't aware of it.
The 2.0 is a tight squeeze as it is.
Andy D said:The V6 engine is much bigger than 2.0 litre ... it's particularly tall.
Fred2001Dynamic said:the 406 lump is vitually the same as the clio V6 engine
but it won't fit
oooh had a thought, what gearbox do they use when they drop the engine in a pug??
j3ned said:The question is ...... why ???? the V6 is as fast as a 182 so whats the point ? i saw a 205 with a 406 V6 lump in at York Dragstrip and it could only manage high 15's
The secret to a powerful car is " power to weight ratio " a powerful lightweight engine in a car that weighs nothing
g18llo said:Simple, and for the same reason it was done in the 205 (although I can only assume that the conversion you saw was poorly executed):
The 3.0 V6 is easily tuneable to 260-280bhp, with relatively simple modifications, and so clearly the P2W ratio would be considerably higher than the 172. In addition to this, the V6 has considerably more torque, considerably lower down the rev range, and this would make it more tractable than the 172 engine.
Regards
Regards
Not even with your big hammer?Fred2001Dynamic said:no it won't fit, not a chance in hell
Andy D said:Seriously? I'm used to Citroen and Peugeot sharing engines because they're obvious both part of the PSA group ... but not Renault too. Only PSA related part I knew about on the V6 was the rear brake calipers.
g18llo said:I'm determined to fit that engine in something else, even if it kills me!!
Regards
Floodie said:maybe it will go in your mouth
Crazy Clio said:50bhp from a re map????
BenR said:step one to making the uk's worst handling clio.......
172 Dave said:Er the WRX also has a bit at the back called a boot and happens per chance to be 4wd!!
They would have to be massive front springs to accomadate that lot, anything is possible but jeeees why did Renault put it in the back! You will have endless grief setting up that geometry!
theduckeatspork said:and yet none of those comparisons are fair as all of the heavier carsvare designed to be faster and better handling! the NA subaru, is in no way shape or form a sports car, as subaru will admit, the st170, a rather poor sports car, the focus rs, an amazing one, the m5, a sports tuned 5series, a 540i, an old mans cruiser. point made
172 Dave said:I agree both Subarus are equal to a degree, however the WRX clearly clearly outpaces the sport so is it a case of the WRX is simply quicker due to the power difference as opposed to the handling characteristics.
Dropping the heavy lump in the front of the Clio is a grand yet optimistic idea, by my reckoning (and if i recall right) the 172 is only just over a tonne in weight, as opposed to the WRX being just short of a tonne and half? (sorry couldnt be fussed to look them up) There is next to no weight over the rear of the Clio, hence the trademark lift off of the rear wheel; you drop the heavy lump in and it will be nose heavy into any apex. Bloody quick i agree and on an airstrip -stunning! Dont think i'd fancy the carousel at the 'ring in it though! Sorry, springs was ill phrased you are right the shocks would primarily sort the extra weight, springs would need uprating too though! I think you would end up with all forms of geometrical problems though to counteract the extra pounds.
Dave
theduckeatspork said:and as everyone here knows, better suspension = better handling! you really answered your own question there, and helped proove my point. thanks 4 that
