this page gives you almost al VAG gearboxes (almost at the bottom are the 02m's):
http://www.clubgti.com/forum/archive/index.php?t-115595.html
i bought myself a fmn from a 2003 s3. this one is not in the list but ratio's won't be far of from the older dqb s3 gearbox.
would need longer final drive for turbo use tbh. (diesel is mental!)
the box is for quattro but going to buy myself an eliminator kit for the transfer box.
trigger wheel would be interesting as i'm willing to use oe management but if it isn't possible it just isn't and i'm going standalone
i won't be supplying a car i think cause my gtt is sitting in the Netherlands
would be more interesting to use your RS? i will have to make custom mounts myself i think
also using bottom mounted F7R btw
chris snapped the 9mm bolts off. but ofcourse he is running more than 600hp and uses an on off clutch :rasp:
i don't like the idea off drilling my crank because the whole engine is already completely built, but it's better to be done once and good than not good and to strip the whole crap again!
