Value of mk1 ktec stealth
Car  Meg 230 R26 F1
Can anyone give me a guide price for a stainless steel custom or possibly a mk1 ktec stealth (no markings, but was told it was this when i bought it from a member of here) exhaust for a clio 172. it has covered around 6000 miles.
however, it was originally used without a cat, so i had it cut down and fitted with the correct flange to fit a cat.
there are no holes or anything, works fine.
thanks
Cut down ? This means it will have shrunk your market big time. I say 100 pounds, probably much less, from cat to end that is.
centre box or no centre box mate?
post a picture because i have been after one and dont mind a bit of welding
it still has centre section and rear box, both brackets are in correct place...it was far too long to fit originally, so had to be cut to fit...you wouldnt notice any difference as the welding is spot on
its gettin dark, but i'll see what i can photo
the first pic looks a little messy around the exhaust clamps, but that because i was in a poor position under the car trying to paste on gun gum (just as a precaution really, does not blow without it)
That is not a K-tec stealth system...
Also seems to have a dint in the pipe work that goes over the rear axel?
its on A MK2 PH1 172, but i dont know what ktec called, if it is a ktec system. (if not i'll just sell it as a custom system)
the photo does look like a dent, but im pretty sure theres not one there, and its just a result of camera flash...
so any ideas of value, after pics?
thanks
ok, thanks for info...was hoping for a bit more than £50, but dont want to mug anyone off.
might just stick it on ebay when i take it off and see what happens
