hazzaslim Car 2007 Clio 197 r27 Apr 2, 2013 #1 Need the specs for my valve clearances, does anybody know where I can find them?? Thanks
ben lee Car mk2ph1 rsi 106rallye Apr 2, 2013 #2 is it an 8v or 16v? do you know the full engine code?
ScottL Car 1.2 Clio Expression Apr 2, 2013 #3 1.2 8 Valve Inlet (D7F) 0.10mm Exhaust (D7F) 0.20mm 1.2 16 Valve Inlet (D4F) 0.05 to 0.12mm Exhaust (D4F) 0.15 to 0.22mm Hope this helps Scott
hazzaslim Car 2007 Clio 197 r27 Apr 2, 2013 #4 Ledgend mate it's a 16 valver does it matter if its a mk 3? An where u get this info? thanks
ben lee Car mk2ph1 rsi 106rallye Apr 2, 2013 #5 for a 2008 1.2 16v camshaft with grove in 0.25-0.32 ex 0.35- 0.42 camshaft without grove in 0.10-0.17 ex 0.20-0.27 from autodata 2013.
hazzaslim Car 2007 Clio 197 r27 Apr 2, 2013 #6 ben lee said: for a 2008 1.2 16v camshaft with grove in 0.25-0.32 ex 0.35- 0.42 camshaft without grove in 0.10-0.17 ex 0.20-0.27 from autodata 2013. Click to expand... Can not thank u enough mate!
