valve removal?
cafcross
i remember reading that theres a valve under the wheel arch (or thereabouts) that you can remove. can't remmeber what it's called or what it does.
fil_b
  172 FF and Fabia VRS
can be removed
not sure if makes a diff
when u remove it, there is a small pipe that runs from it - needs a screw in the end
  BMW M135i
If its working then leave it be. No real benefit, only saves weight but there isn't that much point in a 1.2 tbh.
