ok i need a bigger brake setup on my valver, i can get discs for super cheap so only need the brackets, but i need to know what the disc's are originally off???
You don't need bigger disks better pads are all thats required or different calipers.
I'm not sure what your after though regards what the disk are originally off? The 285mm disk Ktec use are off a R19 or 21 apparently but I've never looked.
The 172.182 280mm disk will fit wif you get brackets but the enxtra weight is argued by many to make the handling worse as its extra weight.
