jumped in it tonight to drive home from work but it wont start, there was no noise from the fuel pump and the one light on the dash which normally lights up didnt, looks like a heart monitor. What can it be, what can I do? Dom
My immob was removed years ago because it failed, other ideas that are coming up are fuse-checked that, and main injection relay but Im not sure where that is
On Ignition, with my immobiliser disarmed, I only have 3 lights on - Oil Pressure, Battery and Handbrake. (Middle 3 below Outside Temp)
This "heart rate" thing.. apparently, it should turn on.. and then turn off on Ignition - if it comes on when driving etc.. you got a problem. (According to Renault manual).
In my Renault Williams manual, tho, it's down as not used - which probably explains why I've never seen it light up! (Dunno if that's just Williams or includes 16v also? :S)
Is your engine turning? Or is it just totally dead?
replaced 8k ish ago, the problem is the fuel pump not receiving info from the ecu the garage think, they are replacing the crank sensor to see if that does anything. ??? GGGGRRRR £££££££
