valver problems sorted at last!!!
ok so ive fixed my car at last!!!!!! i dunno if you guys remember but i messaged up a few times with my problems just wanted to say cheers and thanx to some help from some of you ive got most of the things sorted.
The weird ''stearing to the left and having misfireing problems'' was the hardest yet most simple thing took it to a load of garages and none could work it out they pluged it in and came up with all sorts of faults '' which i couldnt seem to match up with my car as it was only happening when i turned left.
After looking yesterday i found out the dogbone mount was f**ked and changed it then found out that when i went left the engine would shift to the right then found out the problem that the little air hose that goes into the mapping unit was getting squashed when turning left so no or not as much air could get through.
so i thought id post it up incase anyone else ever got this weird problem...............................................
