Nissan 200sx s14,clio 16v
Ive just bought my 2nd clio 16v, naples red, m reg, it has a few problems i thought id check to see if any1 knows the answer to or has fixed these problems!! if so how do you fix them!!
1. it runs very cold, i did over a 100 mile and it never got up to half way on the dial, iam thinking either thermostat is stuck open or has been removed!!
2. when you give it some stick it pulls from side to side, iam thinking this is the driveshafts as it makes wierd noises when you turn!!
3. wipers dont cancel
4. oil leak from under exhaust manifold, heard it could be oil pump
5. oil pressure dial doesnt work or clock
any help on any issue will be a help!!
