J justin_ Nov 15, 2010 #1 would a set of vauxhall 14" fit an mk2 cilo?? only wondering as my mate got some and fancy something bit different?? cheers
J jack_kemp Car Stripped yozza'd cup Nov 15, 2010 #2 Just check the bolt spacing.... And there's your answer
J JoeyD Car Recaro'd MX5 Nov 15, 2010 #4 The centre bore is smaller IIRC, so you might need to get them bored out...
J JoeyD Car Recaro'd MX5 Nov 15, 2010 #6 http://motors-parts.shop.ebay.co.uk/Car-Wheels-Tyres-Trims-/14770/i.html?rt=nc&LH_ItemCondition=2&_nkw=Clio%20wheels&_catref=1&_fln=1&_ssov=1&_trksid=p3286.c0.m282 Or pay your £10 membership and have a look in the For Sale section on here!
B Beef-Mc Nov 15, 2010 #7 Could get some spigot rings that will reduce the centre bore, PCD is similar as is ofset IIRC.
J JoeyD Car Recaro'd MX5 Nov 15, 2010 #9 Centre bore for Vauxhalls is 57.1mm IIRC & Renault is 60.1mm - so you need to make them bigger. Spigot Rings are placed inside the centre bore to make it smaller. E.g. from 70mm to 60.1mm
SteveS Cup Car Iceberg 172 Nov 15, 2010 #10 JoeyD said: Centre bore for Vauxhalls is 57.1mm IIRC & Renault is 60.1mm - so you need to make them bigger. Spigot Rings are placed inside the centre bore to make it smaller. E.g. from 70mm to 60.1mm Click to expand... Come again??? Surely if you was putting a 57.1mm centre bored wheel on a clio you'd need to make it bigger not smaller!?
A Andyrg@ ClioTurbo Car Trophy Turbo :) Nov 15, 2010 #11 hes stated bigger but in his explination said smaller he should have said adjust the size
SteveS Cup Car Iceberg 172 Nov 15, 2010 #12 Sorry, I'm tired and I've just read it agian and it now makes sense! Sorry!!!
