Vented Discs on a Mk1 RT
So may have been asked before but I cant find it!
Right the brakes on me RT are terrible, since I only just got it I thought they were just worn but had a look and theyre fine. Would it be possible for me to get the calipers off a 16V/RSi/Williams and whack them on with vented discs? Wasnt sure with them having wide arches?
you can swap your calipers etc for valver brakes. youll need different bolts though.
why not just buy an uprated set of discs and pads for yours?
I did the 16v/Williams Brake conversion - the difference is incredible. Well worth it.. cost about £106 with brand new discs and pads.. (£40 for the calipers and everything.. £66 for the new discs/pads)
Daz, did you need to use different bolts or spacers to attach the calipers or did they go straight on?
dont jus buy uprated RT brakes there still sh*te
get some 16v discs, pads and calipers and the bolts u can get from Renault
even standard 16v stuff is better than top spec uprated RT stuff
The RT will only have 1 pots! As Brun says uprated pads and discs will make naff all difference..you need more pistons and so bigger pads for a bigger contact patch.
-Rob
