Very slight squeak from cold (belt related)
Poopensharten
  Golf R
Hi guys, on start up of the Phase 1 172, there seems to be a very slight squeak coming from the alternator belt maybe? As soon as the cars warm it goes away no problem, no other symptoms to report on?
I gather replacing the belt will sort this out? Timing belt was done 30k ago btw.
Thanks!
  DON'T SEND ME PM'S!!
aux tensioner is probably sticking/seized. Replace the kit and it should fix it. Battery would be on the list to consider too as it'll be the extra load on the alternator after a cold start that's causing the slip
it's a bumper off job IMO (though some disagree)
Tips aren't easy to give as I've made a special tool for the tensioner because of where it is/access
davo172
  TCR'd 172
so battery could be a cause too ? would it also not struggle to start thou ?
