http://www.cliosport.net/forum/show...a-red-bus-friendly-speed-bump-a-bit-too-quick
Was it doing this before the above ?!
Ok .. well in that case, it sounds like warped discs.
Check for sticky calipers, but replace the discs/pads and don't sit on the brakes at the lights![]()
Sounds like pad residue on discs tbh or "warping".
Just out of curiosity what pads are you using?
I get it sometimes on my 200. No doubt everyone will have a different way of going about it but I get the brakes hot after a few heavy ish braking sets & then drive for a while without using the brakes to let them cool. park without the h-brake on (leave it in gear).
Works for me.
So thrash it, brake hard then don't use them and park without the handbrake on? Thank you.
I would say OEM ones, but they squeal like hell even though there's probably a 1/3'rd left on them. I think they're cheapo's.
That was my thinking too :approve:
I've had problems in the past with some types of pads leaving deposits on the discs it's happened with cheap pads and also some "uprated" after market ones once I thought the car was going to fall apart the vibration was that bad changed pads problem sorted.
Rears on my 200 do it all the time bud. Get on the anchors & it clears them off nicely.
I've got into the habit of using handbrake at lights, the brakes don't seem as bad now tbh. Much smoother, maybe I've cured it. Cheers dude! Will get some good pads next time, at next service.
