Vibration from Climate control fan
  Clio 197 + Mrk 3 DCI
Hiya budding petrol heads....
Ive got a Vibration from Climate control fan by the interior light. Ive taken the fan off, cleaned it a bit, it doesnt make a noise when its in my hand and On. There just tends to be a constant humming vibration once that area is clipped back.
Anyone else had this issue?
  Clio 172
Same sort of thing I found. Could try a second hand housing from a scrappy first if you think its the mountings.
Generally, I THINK, its the fan causing the unit to vibrate in its mountings, because the fan is on its way out.
  It's A Reno
Is it easy to take the housing to bits, 'cos mine's been doing this for a while. I may have to investigate.
  172
most of the noise seems to come from the housing itself so i can't see replacing the fan helping too much... i've tried filling the casing with foam & sticking tape round all the fixings to get rid of some of the vibration but it hasn't made a massive amount of difference. I've just accepted its a s**t design
mines the same, yozza sorts the noise out for me!
Yozza?
With regards to taking the housing off, its very easy just use a flat head screwdriver to take the light out firts, the rest just pulls off.
So there isnt really any exact fix for this issue is there?
