Vibration from Climate control fan
Car  Clio 197 + Mrk 3 DCI
Hiya budding petrol heads....
Ive got a Vibration from Climate control fan by the interior light. Ive taken the fan off, cleaned it a bit, it doesnt make a noise when its in my hand and On. There just tends to be a constant humming vibration once that area is clipped back.
Anyone else had this issue?
Same sort of thing I found. Could try a second hand housing from a scrappy first if you think its the mountings.
Generally, I THINK, its the fan causing the unit to vibrate in its mountings, because the fan is on its way out.
Is it easy to take the housing to bits, 'cos mine's been doing this for a while. I may have to investigate.
most of the noise seems to come from the housing itself so i can't see replacing the fan helping too much... i've tried filling the casing with foam & sticking tape round all the fixings to get rid of some of the vibration but it hasn't made a massive amount of difference. I've just accepted its a s**t design
mines the same, yozza sorts the noise out for me!
Yozza?
With regards to taking the housing off, its very easy just use a flat head screwdriver to take the light out firts, the rest just pulls off.
So there isnt really any exact fix for this issue is there?
