Vibration under load
m4rekchmiel
Car  Clio 172 phase 1
Hey guys! I bought a 172 last year - the car vibrates/ shakes quite violently (you can literally feel the doors rattle) under full throttle, especially around 3000-5000 rpm, then stops near the redline, only does this under load. It has polyurethane engine mounts and dogbone, the symptoms get worse when it's cold, then improve as the car warms up. Could it be some sort of misfire issue? I was thinking of doing sparks/leads/coil. Cheers!
Might be worthwhile doing a routine service changing those bits to at least rule them out.
