vmaxx help please someone.
Car  coiled 'berg
took delivery of my vmaxxs today, and i hadn't realised that you can adjust the camber, i thought they were fixed.
what should i be setting them to, centre?, or not?
cheers all.
You want to have negative camber (the top of the wheel is closer to the car than the bottom), and the easiest way is to have the car aligned after you're happy with the set ride height (allow a week or 2 to let the springs settle in). The chaps with Hunter equipment normal know what they are doing and you can find a centre near you here.
If you want to expanded you're experience, you can align a car using string; a search on Google will bring up the method.
Phil
Thanks mate for the link, turns out there is a centre 3 miles away! Will price up tracking and camber. Cheers
