You have a twin barrel cat but you only need to buy 1 decat to replace it.
This is an example of the decat you want to buy http://www.k-tecracing.com/show_product.asp?id=2034&appid=2
Look at your exhaust and see if there is a lambda sensor after the twin barrel part (I am guessing you haven't with being on a W plate).... if there is NOT then go for the single lambda decat in the list.
Cheers fella, see your local to me
Thought the early ph1's were single box, later spec ones twin type :S
As for the decat, Janspeed silenced is good.
Where are you located mate?
Canvey mate, you had your Clio long?
The first 172's were single cats,i know because i had to change it to a twin from my later 172 when i changed my wiring harness over.
no, all ph1's were twin cat. (give or take a few odditys)
About a month and it already needs a new dephaser!
How i understood it:
Early ph1 172's had the single silenced type box with one lambda
Next was a twin barrel cat with single lambda
The last in the line ph1's, twin cat and twin lambda
