Wandering or unease at speed?
Car  2003 Clio 172
Hey everone, haven't posted in a bit, ownership has been remarkably trouble free with the wee Clio (touch wood)
However, I gave the car a wee bit of abuse the other night and ventured into "overtaking speeds" on a very quiet private runway.
Was a wee bit shocked as the car was very unstable and was wandering alot, was very unnerving.
Now, when i bought the car one of the front springs was broken and one of the rear shocks had just been replaced (ONE! - madness)
Anyway, I duly replaced both front springs with items from Ferret on here and also sourced an identical rear shock and brought the rear into balance as well.
I also went to town on bushes and joints replacing bottom ball joints, top mounts, bearings and adding top mount spacers.
The car was also sent for alignment to a very reputable local place and all was well as far as I was concerned, although I never ventured into big speed.
Car handles fantastically otherwise and i havent noticed excessive tyre wear.
The only thing that has changed since all of the above was brand new Continental CS3's all round, dont think that would have a detiremental effect on handling though.
Since I noticed this, I had it somewhere else to get the alignment checked and it came back as perfect, so thats 2 local places maintinaing the alignment is on the money.
Now, I havent got under the car to check all busings and joints as I havent been well of late but plan to do this as and when i am well to do so.
Anyone any ideas of prime candidates for this behavior?
Just to summarise, terrible wandering and unease at speeds over 80
Help
Andy
Maybe to do with only replacing the one damper. The other one might be worn out now
guys, thats what i am saying.......just ONE rear damper was replaced just before i bought the car on an MOT advisory.....which is madness.
so i immediatey sourced an identical new one for the other side
nothing is out of sync ns/os on the car.....i made sure of that
ill check the trackrod ends today
regards
andy
right.......checked all of the front joints all all are ok (checked for play by disassembling and also using a crowbar when assembled)
they were only renewed a while ago
but s**t me, its not nice at speed
am i missing something obvious here?
j
Ach, wtf.......car has totally mauled 2 new contis up front....well, around 6 months old. :-(
Insides are totally eaten yet alignment checked twice at separate and reputable places showed no issue
What is going on?
Help!
Jinj
What is going on?
Help!
Jinj
That does sound frustrating - I would look at the inner rod joints where it conects to the rack. Is there an obvious knock when you turn the steering side to side whilst stationary?
I would also swap front wheels to rear and see what you think of the handling then. But i think something is wrong with the toe, even though you have had it checked it must be play in joints to cause inner edge wear like you say.
