Want higher revs at idle
Just a bit: my car pops out of third gear under heavy braking on the track. Really tried everything.
Under hard braking the rpm's fall back very quick and it makes the engine stumble a bit (I think).
Maybe the stumbling makes it kick the third gear out.
So i was wondering if the higher idle will prevent the kick out.
I don't think adjusting the idle would do anything to help your issue.
Is your ABS kicking in or wheels locking up when it pops out of gear?
I don't have ABS (anymore) on my car.
I don't heel and toe. Never tried it. Could be the solution ... ...
I do brake on the engine.
On the Ring you have to brake really hard in third gear. The cars revs from all the way up to all the way down real quick. That's when it pops out. So, it pops out before i can release the brake pedal to go to the brake pedal (to engage second gear for instance). Most of the times you just want it to stay in third.
You need to be checking your engine and gearbox mounts along with the dogbone mount/bushes.
If they all check out good it's an internal box issue.
@NorthloopCup: you're right, I know ... ...
Engine movement should be visible when revving at standstill?
What's the best way to check for the right linkage setting?
Any idea how to check if the retainers are the problem?
Thanxs for your answers. Really helps me.
Grab the back of the inlet manifold and try to pull it towards you as hard as you can mate. Look out for any movement.
Gear linkage is a doubtful one tbh unless you've moved it at all recently? If not, discount it, but check the linkage for free play at the gearbox end from underneath.
Retainers are only check able with the box open. Could also be the 3rd/4th gear selector fork worn.
I'm assuming you ain't uk based?
No, I live in The Netherlands.
I have checked the movement of the engine. Rock solid. All KTEC mounts en bushes. No movement at all.
The Retainers and Forks have all been revised by a Renault Sport Specialist. When the problem occurred he first checked to box by opening it. No problems found. When the problem stayed again he mounted another revised and strengthened box. Still the same ... ...
Really cannot figure it out. The pop out only happens on track when its hot.
Its driving me nuts and its very dangerous when you lose gears in a corner ... ...
Without hijacking the thread, I've got a similar sort of problem on my 182.
It's quite hard to explain but when changing from 1st to 2nd, sometimes it kind of pops out when you are just moving it out of 1st. Heard of something like this before? I've got a modified scenic shifter from Ash-B on here and had that on a while but only noticed this recently. Changed gearbox oil about a month ago with Elf NJF or whatever it is and polybushed the dogbone but that's it.
It could be the retainer for the selector hub has worn/lost its tension mate. There isn't really much else it could be tbh.
It's weird cos it doesn't do it all the time and tbh it isn't the worse thing in the world, it just bugs me a bit. If it was the retainer, what's involved with sorting it? Big job? Noticed a leak from the gear selector but, from research, this seems pretty normal.
