Warning light....
Car  Cup Turbo, Flamer
What does this warning light mean.....Orange box with a squiggly line through it? I'm at work and don't want to wait until i get home to find out!
Book says "Electronic fault and preheating warning light"
Preheating Warning light : indicates the heater plugs are switched on, it should go out after engine is started
Electronic fault warning lights up when driving if you have a electrical or electronic fault.
Nice one cheers, it came on driving through germany on the way back from the ring, going down the autobahn at 120 and the car felt like it hit the limiter, happened another 2 times at the same speed then that warning light came on? Any ideas on that one??
that would be limp mode, where the ecu has found a fault it cant deal with properly and cut the engine back to get ya home, mine used to do it when i ran 95 ron in it :(
