Warning lights + STOP light
TRH_Racing
South East - Herts/London
Started the car up the other day after stopping for 2 minutes and I have abs, ESP, STOP lights on the dash board and no speedo
I've checked the rear ABS sensors and cleaned them up but still no luck .. its my only car and is needed for work and I can't currently use it!
Any help ?
TRH_Racing
For some reason I thought you had a cup. The abs rings picks the speedo sensor up.
We've check the back sensors already and cleaned them up, I'll have to do the fronts after work in day light
You need to have the codes read Ali . Only then will you know what wheel is not sending the signal
Joes offered to check it for me, my obd reader gives nothing useful out
