cheers mate, and i know i had that issue yesterday, my plan was to remove the bottle but i got inside and saw all the silver parts of the linkage and tbh i just didnt fancy it.Hi Mate.
I had to change my bottle recently and yes, you have to remove EVERYTHING! It's quite easy as long as your wiper arms haven't seized on (like mine were!). I ended up using a ball joint remover which got the arms off in 5 minutes! Be careful not to try and pry the wipers off with a lever, you could crack the windscreen.
Yep and I cracked the windscreen yesterday trying this, still siezed though and didnt get it off
so you had to replace your windscreen after it right? I'm jut gonna try and repair it, cracks from the edge of your windscreen are s**t though
i thought if it was from the edge it was kinda illegal no ?as in getting the crack resin sealed (repaired)
Alot of cracks that window places say need replacing can actually be repaired, it's just money making really..
