Clio Sport
Hi guys,
Any help/tips would be welcome:
I have a 2004 Clio & both the front and rear window washers dont work. The reservoir is full, ive made sure the holes are clear and the 2 motors which i guess are for the front and rear screens are making the normal noises that come from washing your windscreens and vibrating when i place my fingers on them.
Ive just taken off the wipers, removed the scuttle and looked for any obvious faults but cannot see any. I removed some piping for the rear jets and it dribbled out when pulling on the indicator but nothing when i did the same from the front. I did plan on removing the reservoir but it looks tougher to do than i thought - Do you remove it via the passenger footwell as the wiper mechanism is in the way under the bonet!?
Thanks in advance
P.s Ive done a search and it seems the usual fault is with the motors but surely they both dont fail at the same time & they make the right noises
Thanks in advance
