Washer pumps
alexaj23
Evening all,
I need to replace both washer pumps as I believe the rubber seal/bung in the main pump is stopping the rear washer working and also the headlight washer doesn't operate.
Am I right in thinking that the pumps are both the same (therefore I need to buy 2) and if so, how is the 2nd outlet on the headlight washer blocked off?
Ta
Both pumps are the same.
What do you mean about the 2nd outlet being blocked off for the headlight washer? It's 2 outlets, each washer has its own outlet supply.
