Toyota MR2
It sounds like a boat and the engine management is flashing.
What do i do?
What do i do?
Got it sorted and sounding shweeeeeeet again cheers guys!
Still running like a powerboat this morning. It's not had a lot of water but clearly enough to do this.
Should I run it and try to dry out or take the the garage?
I really really don't understand why anyone would put water on an engine. Literally asking for trouble.
Take the ignition leads off mate. have a look down the plug hole and see if you can see any water. DONT remove the plugs because if there is water down the plug holes it will just fall into the cylinder!
If there is water down the plug holes then turn car off and blow it out with an air line or try and dry it best you can with paper towell.
Then when you've dried it as best you can leave it running for a while to try and dry it off fully.
Turn the car upside down so it can drain out and put in a bowl of dry rice.
