Water getting in
  clio rs tropy
Good morning
Have a 16 plate rs
And the floor is soaked through
Car has been parked for a 2 weeks not much movement and the rain fall has been not to bad but the floor is soaked through
Any suggestions on where to start looking
Matt Cup
  Leon Cupra, 172 Cup
Where in the floor?
Front/ back/ boot?
Damaged seal’s and clogged drainage channels would be first points to look at.
Mr Trailer Man
First port of call is to check the scuttle drains.
Wipers off, cover off and get a stiff wire/rod down the rubber drains.
Worth checking for water marks along the bottom of the doors and inner sill plastic trims too, incase the doorcard membrane has come away or been messed with previously.
Worst thing is, you're going to have to remove the carpets and foam underneath to dry it out properly :rolleyes:
  clio rs tropy
You were spot on
Took it all off there and it was full of water
No only handy thing is I already had the foam taken out of the passenger side of the car from sorting something else
So now it’s rip it all out on Sunday and see what happens
Mr Trailer Man
You were spot on
Give the drains a good clean through with water.
They have a flap of rubber at the bottom which is why they get blocked. Leaf and dirt build up and get stuck.
It'll take a while to dry.
