Water in the car (LHD) - inside the glove box
  Clio MkII 172 K reg
Hi everyone,
I washed my car today (all windows were closed for sure) and few minutes ago found water on the passenger's rubber mat (not on the floor on factury mats - so the problem is not from the car's floor) and also in the glove box. Must to metion that my car is clio 172 FF Mk2 left hand drive. Also found water under the AC blower place. Tried to find the source of it but without luck.
Anybody had this problem or know from where it leaking ?
Thank you for help.
Lior
Hi everyone,
Thank you for help.
Lior
mate all im gonna say is........its renault:)
  Clio MkII 172 K reg
I know this.:dapprove:
And still, anybody had this problem ? I can't understand how the water come into AC blower house.
mossyv6
  Trophy,V6,5GT,AG200
Bulkhead grommit?? Door seals?? Leaking sunroof/aerial and water running down the A pillars??
  BMW M135i
The engine loom to interior loom plug is on that side, could be leaking through there. Its about the only place I can think of that would let it in.
  Clio MkII 172 K reg
Sorted out hopefully :( .
Inside the Ac blower place there is a drain plug. It was covered with mud + leaves. I removed the wheel arch and the plug and some water come down. Tried to test by put the water on windscreen and all just came down from this plug. I believe that this is what caused the problem because after removing the wheel arch I didn't find any loom or something that come into the interior from there. But, I still can't understand, how the water came into the glove box. Tried to touch behind it to find any wetness but still without any luck.
* My car is left hand drive so we talking about UK driver's side.
  Clio MkII 172 K reg
To prevent this problem to happen again but at driver's side (with UCH $$$), I also cleaned today driver's side like the passenger's.
Last question: I found already 2 times water under the rear seat. the seat we are talking is rear left one (not the one that has under it fuel pump).
Tried to figure out how the water came in but without luck. I removed the whole rear left panel after the driver's seat belt but still can't find the source.:dapprove:
