Water leak (not sunroof)
I jetwashed my car at the weekend and water was dripping inside above the rear passenger window(3dr) onto the plastic behind the rear seats,the roof ditch or if thats what its called above the rear windows on the roof was lifted slightly and i think one of the clips has snapped,should water be able to get in there has anyone else had this and how can i repair it,i was thinking of lifting it and putting sealant underneath,cheers
Ok,why and it was dripping from further towards the front of the car than the arial so it cant be that,there is some plastic trim above the rear window and where it joins to the trim above the boot it was dripping from there,if you look at yours it will make sense lol ,thanks
So you have a 3door with the bit of trim on the roof.
Take that off very carefully as the bend easy.
You will find the seam in the roof is split.
